How to calculate the setup time and hold time of the datasheet report in timing Analysis?
As follows,  How to calculate the hold time(edge)?
Setup/Hold to clock pci_clk
               |  Setup to  |  Hold to   |                  | Clock  |
Source      | clk (edge) | clk (edge) |Internal Clock(s) | Phase  |
io_a_pad[0]    |    0.153(R)|    4.806(R)|pci_clk_int       |   0.000|
io_a_pad[1]    |    0.137(R)|    5.237(R)|pci_clk_int       |   0.000|
io_a_pad[2]    |    0.142(R)|    6.642(R)|pci_clk_int       |   0.000|
io_a_pad[3]    |    0.181(R)|    6.327(R)|pci_clk_int       |   0.000|
io_a_pad[4]    |    0.169(R)|    6.374(R)|pci_clk_int       |   0.000|
io_a_pad[5]    |    0.211(R)|    6.310(R)|pci_clk_int       |   0.000|
io_a_pad[6]    |    0.204(R)|    6.306(R)|pci_clk_int       |   0.000|
io_a_pad[7]    |    0.193(R)|    6.349(R)|pci_clk_int       |   0.000|
io_a_pad[8]    |    0.189(R)|    5.924(R)|pci_clk_int       |   0.000|
io_a_pad[9]    |    0.186(R)|    6.159(R)|pci_clk_int       |   0.000|
io_a_pad[10]   |    0.178(R)|    6.098(R)|pci_clk_int       |   0.000|
io_a_pad[11]   |    0.194(R)|    5.912(R)|pci_clk_int       |   0.000|
io_a_pad[12]   |    0.189(R)|    5.930(R)|pci_clk_int       |   0.000|
io_a_pad[13]   |    0.210(R)|    5.889(R)|pci_clk_int       |   0.000|
anybody can  tell me how to calcauate the time in the  datasheet report in timing Analysis?
setup/hold to clock *****;
clock **** to pad ,
clock to setup on destination clock******,
pad to pad...
Re: How to calculate the setup time and hold time of the datasheet report in timing Analysis?
Dear mrpp,
these tables are an overview of the offset in/out calculations.
if you don't have any offset in/out constraints, you can generate a timing report, select "unconstrained paths" and set a good amount of paths (14 instead of the default 1 or 3)
best regards,
Dries
Give Kudos to a post which you think is helpful and reply oriented by clicking the star next to the post.
