How to check Setup and hold time for each control signal in a design
Hi Folks,
I made design for zynq 7020-clg400 -2 grade.
I am interfacing zynq and FX3.
I need to check my FPGA boundary conditions.
How check each control signal setup and hold time?
Please suggest me regarding this.
Thanks and Best Regards
Vinod Sajjan
Hi @vinod.sajjan
I am assuming you are using Vivado. In that case, you must have written set output delay constraint to define a setup and hold relationship of your control/data signals w.r.t clock. You can open the report timing summary after implementation and  under timing tab click on check timing section. There you will see no_output_delay section which shows all the output ports without set_output_delay constraint.
Seeing this you can make it whether these ports actually need the set_output_delay contraint or not. Any voilations corresponding to the the ports having set_output_delay constraint  can be seen in the report timing summary as well.
Rohit
Rohit
Hi @thakurr,
Thank you for replay.
please suggest me .
how to change setup and hold time here ?
Vinod Sajjan
Hi @vinod.sajjan
I am not sure about your requirement here. Are you facing any set up and hold voilations here hence you want to mitigate it?
You need to share more details about the issue? If there are voilations you need to share the timing reports of the voilating paths.
Rohit
Rohit
Hi @thakurr,
Thank you for support and time.
I attaching my timing report here.
my requirement is I need to set FPGA boundary conditions for interfacing FPGA to FX3.
for FX3 has 2ns setup and hold time for that I need to tune FPGA control signals setup and hold to more than 2ns and bit more.
Vinod Sajjan
