How to constraint toggle FF in ISE?
I'm working on a huge Virtex 6 design where I get a lot of unconstrained pathes in my Timing Report. To analyze some of them, I made a really simple testproject.
My VHDL file for testing, contains a differential clock input and a toggle output.
Now when checking Timing report, I have an unconstrained path from sys_clk_p_in PAD to toggle FF (which makes absolutly sense).
 Timing constraint: Unconstrained path analysis
  2 paths analyzed, 1 endpoint analyzed, 0 failing endpoints
  0 timing errors detected. (0 setup errors, 0 hold errors)
  Maximum delay is   3.434ns.
 Paths for end point toggle (SLICE_X7Y118.CLK), 2 paths
 Delay (setup path):     3.434ns (data path)
   Source:               sys_clk_p_in (PAD)
   Destination:          toggle (FF)
   Data Path Delay:      3.434ns (Levels of Logic = 2)
   Maximum Data Path at Slow Process Corner: sys_clk_p_in to toggle
     Location             Delay type         Delay(ns)  Physical Resource
                                                        Logical Resource(s)
     AF10.I               Tiopi                 1.196   sys_clk_p_in
                                                        sys_clk_p_in
                                                        u_IBUF/IBUFDS
     BUFGCTRL_X0Y0.I0     net (fanout=1)        0.600   clk_ibuf
     BUFGCTRL_X0Y0.O      Tbgcko_O              0.092   u_bufg_sys_clk
                                                        u_bufg_sys_clk
     SLICE_X7Y118.CLK     net (fanout=1)        1.546   sys_clk
     Total                                      3.434ns (1.288ns logic, 2.146ns route)
                                                        (37.5% logic, 62.5% route)
   Source:               sys_clk_n_in (PAD)
   Data Path Delay:      3.434ns (Levels of Logic = 3)
   Maximum Data Path at Slow Process Corner: sys_clk_n_in to toggle
                                                        Logical Resource(s)
     AE10.PADOUT          Tiopp                 0.000   sys_clk_n_in
                                                        sys_clk_n_in
                                                        u_IBUF/SLAVEBUF.DIFFIN
     AF10.DIFFI_IN        net (fanout=1)        0.000   u_IBUF/SLAVEBUF.DIFFIN
     AF10.I               Tiodi                 1.196   sys_clk_p_in
                                                        u_IBUF/IBUFDS
                                                        u_bufg_sys_clk
 Hold Paths: Unconstrained path analysis
 Delay (hold path):      1.492ns (data path)
   Requirement:          0.000ns
   Data Path Delay:      1.492ns (Levels of Logic = 2)
   Minimum Data Path at Fast Process Corner: sys_clk_p_in to toggle
                                                        Logical Resource(s)
     AF10.I               Tiopi                 0.580   sys_clk_p_in
                                                        sys_clk_p_in
                                                        u_IBUF/IBUFDS
     BUFGCTRL_X0Y0.I0     net (fanout=1)        0.231   clk_ibuf
     BUFGCTRL_X0Y0.O      Tbgcko_O              0.033   u_bufg_sys_clk
                                                        u_bufg_sys_clk
     SLICE_X7Y118.CLK     net (fanout=1)        0.648   sys_clk
     Total                                      1.492ns (0.613ns logic, 0.879ns route)
                                                        (41.1% logic, 58.9% route)
   Data Path Delay:      1.492ns (Levels of Logic = 3)
   Minimum Data Path at Fast Process Corner: sys_clk_n_in to toggle
                                                        Logical Resource(s)
                                                        sys_clk_n_in
     AF10.I               Tiodi                 0.580   sys_clk_p_in
                                                        u_IBUF/IBUFDS
                                                        u_bufg_sys_clk
So the question is, how have I to describe this scenario in my UCF, to remove this path?
Thanks a lot and best reagrds
Tobias
Ingenieurbüro Tobias Baumann / FPGA & Embedded System Solutions / https://www.elpra.de
Re: How to constraint toggle FF in ISE?
@ttobsen,
Apply TIG (Timing ignore) constraint on this path. Check the below AR#
http://www.xilinx.com/support/answers/10025.html
--Syed
@ttobsen,
--Syed
Thanks a lot for fast response!
I tried something like this in my UCF:
NET "sys_clk_p_in" TNM_NET = "TNM_sys_clk";
TIMESPEC "TS_sys_clk" = PERIOD "TNM_sys_clk"  6.734 ns;   # 148.5 MHz
NET "sys_clk_p_in" TNM = PADS:"Pads_sys_clk";
NET "sys_clk_n_in" TNM = PADS:"Pads_sys_clk";
TIMESPEC "TS_Pads_sys_clk" = FROM "Pads_sys_clk" TO FFS TIG;
It works perfectly.
Now one question for my understanding: This constraint tells the tool that it doesn't matter for me, how long the time between rising edge on the pad and the rising edge on the FF is?
Lets consider the following timing constraint:
TIMESPEC "TS_Pads_sys_clk" = FROM "Pads_sys_clk" TO FFS 4.0 ns;
Would this tell the tools, that I want to toggle the FF in at least 4 ns after sys_clk_p_in is rising? For my actual project, this is not important, but maybe I can learn something. ;)
Tobias
Professor
Professor
You could do what you're suggesting, but I'm not sure if it would help.  Generally speaking the time from clock input at the FPGA pin to the clock input of a flip-flop is not constrained by itself.  What you're typically interested in is the time from the clock edge at the input pin until the flip-flop's output is stable at an output pin.  This is typically specified as an OFFSET OUT AFTER constraint, and it includes the clock delay to the flip-flop as well as the flip-flop's clock to Q and any output routing path to the pin.  The tools are quite good at doing this, and it allows you to specify the FPGA as a system component to have a particular "data sheet" clock to Q timing measured from pin to pin.
In the ISE GUI there is an item called "Create Timing Constraints" in the Design pane under "User Constraints."  This is a handy tool to create the timing constraints you want and it shows you graphically how they are applied.
-- Gabor
The reason I'm asking, is to decrease the number of unconstrained paths for making my timing report more readable. The output timing of the toggle_q isn't important for this example, because in the real design the toggle_q is an internal signal.
So ignoring the timing to reduce the size of my timing report is absolutly what I need.
Tobias
