01-16-2012 02:59 PM
01-17-2012 05:00 PM
I replied in your duplicate thread in the Spartan forum.
-- Bob Elkind
01-17-2012 03:20 AM
You need to design your system and use an OFFSET OUT if the external device has certain specs to be respected.
01-17-2012 04:46 AM
What is driving the inputs to the OBUFDS output buffers?
What range of alignment is "OK", and what mis-alignment is too much mis-alignment?
-- Bob Elkind
01-17-2012 08:18 AM
Thanks for the reply.
I need to send a signal pattern. So I made the signal pattern insinde the VHDL code. In my current version I'm going to send a very simple signal. I past my VHDL code at the bottom of this post.
The best case I need allignment < 200 ps, but I'm ok with < 800 ps
Thank you again for answering to my post.
-- Company:
-- Engineer:
-- Create Date: 15:51:19 12/27/2011
-- Design Name:
-- Module Name: TDCTestSource - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
library UNISIM;
use Unisim.VComponents.all;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity TDCTestSource is
Port ( clk : in STD_LOGIC;
LED : out STD_LOGIC;
TestOut_p : out STD_LOGIC_VECTOR(15 downto 0);
TestOut_n : out STD_LOGIC_VECTOR(15 downto 0));
end TDCTestSource;
architecture Behavioral of TDCTestSource is
signal SingleEnded : STD_LOGIC_VECTOR(15 downto 0) := "0000000000000000";
begin
OBUFDS_1 : OBUFDS generic map ( IOSTANDARD => "LVDS_25")
port map( O => TestOut_p(0),
OB => TestOut_n(0),
I => SingleEnded(0)
OBUFDS_2 : OBUFDS generic map ( IOSTANDARD => "LVDS_25")
port map( O => TestOut_p(1),
OB => TestOut_n(1),
I => SingleEnded(1)
OBUFDS_3 : OBUFDS generic map ( IOSTANDARD => "LVDS_25")
port map( O => TestOut_p(2),
OB => TestOut_n(2),
I => SingleEnded(2)
OBUFDS_4 : OBUFDS generic map ( IOSTANDARD => "LVDS_25")
port map( O => TestOut_p(3),
OB => TestOut_n(3),
I => SingleEnded(3)
OBUFDS_5 : OBUFDS generic map ( IOSTANDARD => "LVDS_25")
port map( O => TestOut_p(4),
OB => TestOut_n(4),
I => SingleEnded(4)
OBUFDS_6 : OBUFDS generic map ( IOSTANDARD => "LVDS_25")
port map( O => TestOut_p(5),
OB => TestOut_n(5),
I => SingleEnded(5)
OBUFDS_7 : OBUFDS generic map ( IOSTANDARD => "LVDS_25")
port map( O => TestOut_p(6),
OB => TestOut_n(6),
I => SingleEnded(6)
OBUFDS_8 : OBUFDS generic map ( IOSTANDARD => "LVDS_25")
port map( O => TestOut_p(7),
OB => TestOut_n(7),
I => SingleEnded(7)
OBUFDS_9 : OBUFDS generic map ( IOSTANDARD => "LVDS_25")
port map( O => TestOut_p(8),
OB => TestOut_n(8),
I => SingleEnded(8)
OBUFDS_10 : OBUFDS generic map ( IOSTANDARD => "LVDS_25")
port map( O => TestOut_p(9),
OB => TestOut_n(9),
I => SingleEnded(9)
OBUFDS_11 : OBUFDS generic map ( IOSTANDARD => "LVDS_25")
port map( O => TestOut_p(10),
OB => TestOut_n(10),
I => SingleEnded(10)
OBUFDS_12 : OBUFDS generic map ( IOSTANDARD => "LVDS_25")
port map( O => TestOut_p(11),
OB => TestOut_n(11),
I => SingleEnded(11)
OBUFDS_13 : OBUFDS generic map ( IOSTANDARD => "LVDS_25")
port map( O => TestOut_p(12),
OB => TestOut_n(12),
I => SingleEnded(12)
OBUFDS_14 : OBUFDS generic map ( IOSTANDARD => "LVDS_25")
port map( O => TestOut_p(13),
OB => TestOut_n(13),
I => SingleEnded(13)
OBUFDS_15 : OBUFDS generic map ( IOSTANDARD => "LVDS_25")
port map( O => TestOut_p(14),
OB => TestOut_n(14),
I => SingleEnded(14)
OBUFDS_16 : OBUFDS generic map ( IOSTANDARD => "LVDS_25")
port map( O => TestOut_p(15),
OB => TestOut_n(15),
I => SingleEnded(15)
LED <= SingleEnded(0);
Swap : process(clk)
variable count : integer range 0 to 100 := 0;
begin
if(clk = '1' and clk'event) then
if (count < 100) then
count := count + 1;
else
count := 0;
SingleEnded(0) <= not(SingleEnded(0));
SingleEnded(1) <= not(SingleEnded(1));
SingleEnded(2) <= not(SingleEnded(2));
SingleEnded(3) <= not(SingleEnded(3));
SingleEnded(4) <= not(SingleEnded(4));
SingleEnded(5) <= not(SingleEnded(5));
SingleEnded(6) <= not(SingleEnded(6));
SingleEnded(7) <= not(SingleEnded(7));
SingleEnded(8) <= not(SingleEnded(8));
SingleEnded(9) <= not(SingleEnded(9));
SingleEnded(10) <= not(SingleEnded(10));
SingleEnded(11) <= not(SingleEnded(11));
SingleEnded(12) <= not(SingleEnded(12));
SingleEnded(13) <= not(SingleEnded(13));
SingleEnded(14) <= not(SingleEnded(14));
SingleEnded(15) <= not(SingleEnded(15));
end if;
end if;
end process;
end Behavioral;
01-17-2012 05:00 PM
-- Bob Elkind
01-18-2012 11:39 AM
Thanks eteam00
01-22-2012 03:46 PM
One big thing to do would be to make sure the logic is placed in the IOB as well. Check out the MAP commands to do this, or use the option in ISE. Since the data path from register to output pad is deterministic in these ports, with the exection of a few ps of "flight time" for flip-chip packages, the only variation would be the clock skew to each output register. Placing the registers in the same clock region / IO bank will minimize this skew variation. When the registers are in the IOB, the output timing is fixed, and then the OFFSET OUT constraint is really a report only constraint as there is nothing in the data path that can be adjusted.
OK, hope this helps ...
