ldm.eth
How to create a timing report for a certain hierarchy?
Hi All,
How to report a list of violated paths per hierarchy?
Let's say my design has the following structure:
TOP |- hier1 -|- hier11
    |         |- hier12
    |- hier2
    |- hier3 -|- hier31
-|- hier32
So, how can I create the separated violations timing reports for the hier1, hier11, hier12, hier2, hier3, hier31, and hier32?
Thank you!
avrumw
Expert
Expert
You normally wouldn't - timing analysis done this way isn't really useful.
And what would you do with paths that start at one hierarchy and end at another one?
That being said, there is tons of capability in the report_timing command - you can restrict the list of paths it reports in many different ways. As an example, if you wanted to generate a report for paths that end in hier31 (as an example) you would use a command like this
report_timing -max_paths 1000 -to [get_cells hier1/hier3/hier31/* -filter {IS_SEQUENTIAL}]
Avrum
avrumw
Expert
Expert
Avrum
hongh
Hi, @ldm.eth ,
You can also try the below commands to run report_timing on the specified cells:
report_timing -cells hier1/hier11 -name test -max_paths 100
avrumw
Expert
Expert
Hah! You learn something new everyday...
Apparently, this command does indeed report only paths that start and/or end within the specified hierarchy... However, the use of the "-cells" option is not at all clear in the in the documentation... (So I am inferring what it does based on trying it on a known design)
Avrum
hongh
Hi, @avrumw ,
You can refer to AR-63934 for the detailed description of the option:
https://www.xilinx.com/support/answers/63934.html
