Visitor tcl_balaji
How to get default value in swich
I just reading and writing tcl about 10days,
I want to use a switch in Tcl
I use the below code, and I want to show default answer if no option selected:
#!/usr/bin/tclsh
#!/usr/bin/tclsh
puts "Main Menu"
puts "================"
puts "1. Show ip route"
puts "2. ping tftp server"
puts "3. list contents of disk0"
set menuitem 0
switch $menuitem {
1 {
puts "You selected menu item as $menuitem"
2 {
3 {
default {
"you have not selected"
when I set menuitem 1, 2, 3 it works correctly. But when I set menuitem 0, it did not work
Re: How to get default value in swich
Hi @tcl_balaji ,
What happens when you set menuitem default?
Raj
Visitor tcl_balaji
It give error as below:
$tclsh main.tcl
Main Menu ================ 1. Show ip route 2. ping tftp server 3. list contents of disk0 invalid command name "you have not selected" while executing ""you have not selected"" ("default" arm line 2) invoked from within "switch $menuitem { 1 { puts "You selected menu item as $menuitem" } 2 { puts "You selected menu item as $menuitem" } 3 { puts "You selec..." (file "main.tcl" line 13)
