zan_zhan@amat.com
How to pack reg into IOB in HD bank of Kintex Ultra Plus without pulse width violation
Does any know How to pack reg into IOB in HD bank of Kintex Ultra Plus without pulse width timing violation?
I am using 200M clock to drive signals output as SDR which are assigned to HD bank.
With "set_property IOB ture [get ports xxxx]" in xdc, I get below warning after Synthesis and also it looks like these signals are still not packed into IOB.
Thanks in advance!
pthakare
Hi zan_zhan@amat.com
Please refer to the below AR and let us know if you missing anything in writing the IOB attribute/constraints.
https://www.xilinx.com/support/answers/66668.html
Reply if you have any query, Give Kudos and accept as solution if you get one
avrumw
Guide
Guide
I haven't done much work with UtraScale, but I believe that these flip-flops are packed into the IOB...
The Location is "HDIOLOGIC_...", which looks like the IOB flip-flops. If they weren't in the IOB flip-flops, the Location would be something like SLICE_XxxYyy...
These messages are telling you that you are clocking these flip-flops too fast. While you claim that you are using a 200MHz clock, the tools seem to think that they are being clocked at 240Mhz. Furthermore, (and, again, I am not an UltraScale expert) it is telling you that these IO (the HDIO) cannot be clocked at more than 125MHz... If you look at DS922, Table 23 shows that the maximum bit rate for the HD banks are, in fact, 125Mbps in some configurations...
Avrum
