gekuls21
How to reduce Offset Out
Hi, every one.
Currently, I am designing some H/W working on 200MHz using S3A.
But I have a problem. I can't reduce Offset Out although I insert DFF between Logic and IOB.
Offset out must be lower than 5ns.
By the way, it is around 9ns.
Please let me know your Know-How.
jared.chen
Maybe you can use a DCM to do a phase shift on the clock.
Jared
dylan
Also make sure that the FF is actually packed into the IOB.  The timing report will tell you which parts of the path are too long- you'll then have to address the biggest delay offenders.  For example, you'll want to check if most of the delay is in the data path or in the clock path, and proceed from there...
Anonymous
Not applicable
Adding one addtional level of register, and pack it into the IOB will be the easiest way, if you won't make any changes to the clock routing.
