Visitor yynotebook
How vivado do timing analysis with a BUFGMUX?
I just want to know what is the rule of vivado doing timing analysis with a BUFGMUX?
For example: I have a mux of clka and clkb, output of the mux is clk. I know for a single net, vivado won't propagate both clocks on a single net. So How will vivado chose the right clock for this path? Is vivado still supporting "priority" constrain? Thanks
Zoe
Mentor watari
Mentor
Re: How vivado do timing analysis with a BUFGMUX?
Hi @yynotebook
Would you describe "set_case_analysis <val> <location of cell>" on xdc file to do STA ?
example
set_case_analysis 0 [get_pin u_CLK_MUX/S];
Best regards,
Guide avrumw
Guide
In fact, that is exactly what it will do. The net named "clk" will carry both clocks "clka" and "clkb".
This means that any path that has both its startpoint and endpoint connected to the "clk" net will end up with four paths:
  • startpoint @clka to endpoint @clka
  • startpoint @clkb to endpoint @clkb
  • startpoint @clka to endpoint @clkb
  • startpoint @clkb to endpoint @clka
Clearly the last two are false (they are in fact impossible) and hence normally need to be overridden with an exception. If the two clocks go only to the inputs of the BUFGMUX then it is safe to declare the two clocks as "physically_exclusive" clock groups
set_clock_groups -physically_exclusive -group clka -group clkb
This will result in the last two sets of paths being declared false.
The first two paths, though, are both timed - the tools will check each path on both clka and clkb.
Avrum
