andy.watts
ISE/UCF Timing Constraints
I have shuffled things around in a previously working design and am having trouble with the following timing contraint.
 NET "clk_40m" TNM_NET = "clk_40m";
 NET "clk_64m" TNM_NET = "clk_64m";
TIMESPEC TS_clk_40m_to_clk_64m = FROM "clk_40m" TO "clk_64m" TIG;
This worked fine when these timing nets were in the top level implementation file but now they are another level down the build fails.
I have tried all obvious things such as:
 NET "sec_level_inst/clk_40m" TNM_NET = "clk_40m";
But I cannot get anything to work.
vemulad
Open Technology schematic and find out the net name which is connected to clk_40m pin of submodule. Use this new net name in the UCF.
Deepika.
Deepika.
vemulad
Deepika.
Deepika.
