elvisjohndowson
Including XDC files hierarchically
     Is it possible to include XDC files hierarchically, e.g. have a system_constr_top.xdc, which in turn includes the following additional xdc files:
system_constr_pinout.xdc
system_constr_clock.xdc
system_constr_impl.xdc
rather than configuring the relative orders via the constraint file properties?
Elvis Dowson
yenigal
You can specify all the constraints in a single XDC file or in multiple XDC files and set the relative order.
Using a sigle XDC and specifying other XDC file types in this is not allowed.
Have a look at the below pdf for  the supported XDC flows
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_4/ug903-vivado-using-constraints.pdf
Satish
