hyleung
Incorrect period reported in automatically derived clocks
I have a clock generation block axi_clkgen_v1_0, in a Vivado block design.  The clkin period is set to 4 manually.  The Clk0 Div is set to 4.  I expect the clock period from this block is 16ns.  But the report_clocks shows the period of the output of the MMCM is 4:
Source clock to the clkgen block:
rx_div_clk 4.000 {0.000 2.000} P {i_system_wrapper/system_i/util_adrv9009_xcvr/inst/i_xch_0/i_gthe4_channel/RXOUTCLK}
Derived clocks from the block:
mmcm_fb_clk_s 4.000 {0.000 2.000} P,G,A {i_system_wrapper/system_i/axi_adrv9009_rx_clkgen/inst/i_mmcm_drp/i_mmcme4/CLKFBOUT}
mmcm_clk_0_s 4.000 {0.000 2.000} P,G,A {i_system_wrapper/system_i/axi_adrv9009_rx_clkgen/inst/i_mmcm_drp/i_mmcme4/CLKOUT0}
mmcm_clk_1_s 6.000 {0.000 3.000} P,G,A {i_system_wrapper/system_i/axi_adrv9009_rx_clkgen/inst/i_mmcm_drp/i_mmcme4/CLKOUT1}
mmcm_clk_2_s 2.000 {0.000 1.000} P,G,A {i_system_wrapper/system_i/axi_adrv9009_rx_clkgen/inst/i_mmcm_drp/i_mmcme4/CLKOUT2}
Any comment or help to correct the period are welcome.
yashp
Looks like the IP configuration is not set correctly. Please revisit the output clock parameters.
Yash
hyleung
Hi Yash,
Thanks for your reply.  This is a design from ADI.  It happened that the rx_div_clk, supposedly a auto-derived clock from a mmcm, has forced by a create_clock of 4ns in one of the tcl file.  Because of this create_clock, Vivado has problem in propagate the delay down the clocking network.  I fixed it by a bandage solution: write another create_clock to the correct timing at the output of axi_clkgen_v1_0.
Henry
