Is there an advantage to constrant the frequency to be higher than the real frequency?
hi,
if i want to enhance the reliability of the logic code, is it helpful to increase the constrant frequency of clock in ucf file ?
for example, the real global clock is 40mhz, the constrant of the clock frequency be set to 50mhz.
thanks, huang.
Hi huangj852010@163.com,
You can see maximum frequency met by the design in .twr file.
ISE timing tools are pessimistic, so ideally there is no need for increasing clock frequency.
In case you still want to over constrain the design, please go for adding system jitter.
Arpan
I don't think there is really an advantage in over-constraining a clock. If the design is passing timing then the design shouldn't fail in HW.
Florent
Florent
ISE timing tool has considered the most pessimistic situation if your constraint is correctly set.
No need to overconstrain the design for the purpose of reliability.
Arpan
Thank you all for help, but could you tell me how to add the system jitter?
Please go through page-269 and 270 of https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_4/cgd.pdf for syntax of system jitter.
Arpan
