Anonymous
Not applicable
Is there any gui in Vivado for entering timing constraints
I am using vivado 2013.3.
In ISE, there was a gui to enter timing constraints which detected all clocks. All we had to do is just enter values and they were saved in UCF.
Is there any such functionality in vivado?
vemulad
You need to open synthesized design to see that option.Click on Synthesized design in Flow navigator to open synthesized design.
Deepika.
Deepika.
vemulad
Try this.
Open synthesized design and go to "Tools-->Edit timing constraints" to open the constraint wizard.
Deepika.
Deepika.
Anonymous
Not applicable
"Open synthesized design and go to "Tools-->Edit timing constraints" to open the constraint wizard. "
There is no such option in tools as you cxan see in attachment.
vemulad
Deepika.
Deepika.
Anonymous
Not applicable
Oh i found it under "synthesized design" .
driesd
Indeed, Vivado has an integrated with tens of tools and hundreds of commands.
To reduce complexity, the interface is context-driven.
Only in synthesized design, does  the tool have the data required to adequately generate timing constraints.
2014.1, scheduled to be released April 16th, will have a constraints wizard which is an addition to the current editor.
The wizard will analyze the design and guide the user through all possible constraints.
Best regards
Dries
Give Kudos to a post which you think is helpful and reply oriented by clicking the star next to the post.
