LVDS I/O constraints
FPGA I/O (1-bit) via LVDS requires use of specially designated pin-pairs on the FPGA.  These LVDS pin-pairs have a P-side and an N-side.  However, for LVDS I/O, we write a constraint (eg. set_input_delay, set_output_delay) only for the P-side of the pin-pair.
What assumptions are we making by not writing a constraint for the N-side of the pin-pair?  Other cautions?
Voyager
Voyager
Hey markg@prosensing.com,
I think the basic assumptions are:
  • The N-side uses the same I/O Standard/Drive/Slew/etc as the P-side
  • The pair is matched properly (routed with identical length)
Best,
Herbert
-------------- Yes, I do this for fun!
Voyager
Voyager
Best,
Herbert
Guide
Guide
A P/N pair of a differential signal is really a single signal - it is just carried over a pair of wires and pins. The signal should have only one timing constraint, which should be applied to the P pin - you should never put timing constraints on the N pin.
For the physical constraints, the tools assume that if the P side is configured with a particular differential standard (and associated properties) the N side will be the same. However, in this case, it is legal (but not necessary) to apply the properties to both the N and P.
Avrum
Herbert - thanks!  My Googling found articles describing proper design of LVDS traces on a circuit board.  -and, if followed, will result in the assumed-conditions you have listed.
Avrum - thanks for clarifying the needed timing constraints ... and for the reminder about the needed physical constraints!
Voyager
Voyager
You're welcome!
All the best,
Herbert
