al_gm
Multicycle paths with Vivado and Synplify
Hi all,
I am using a synthesis flow where I perform synthesis with Synplify Pro, and then perform P&R with Vivado.
I would like to relax constraints for some signals by setting a multicycle path. But I was wondering...
Should I define the constraint in Synplify only? Vivado only? Both?
I believe the correct thing to do would be to mark the registers with a *keep* attribute at synthesis and then constraint the multicycle path only at P&R. What do you think?
Thanks for your feedback!
nagabhar
HI @al_gm
Yes.
As the post P&R timing analysis is what that matters.
Once you import the synthesized netlist from synplify into vivado. You can identify the register-registers path which needs  the multicycle path exceptions and apply them in an xdc file,  which will be used for implementation(P&R).
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
nagabhar
HI @al_gm
Yes.
Bharath
