dharpeer
Multiple clocks on same object
In a Xilinx document, I came across the following,
create_clock -name clk1 -period 10 [get_ports clk_in1]
create_clock -name clk2 -period 5 [get_ports clk_in1] -add
As per the document both clocks are attached to the same port. I am confused as to how this can be done, given it is the same port.
Thanks in advance.
hongh
Hi, @dharpeer ,
Yes, in this way, both clocks will detected and work in the design.
hongh
You can image a scenario in which the input clock frequency will be switched. Sometimes the design will work for 200Mhz and sometimes the design will work for 100Mhz. Of course, these 2 frequency can not work at the same time.
With your 2 clock constraints, tool can calculate whether 2 clocks of the different frequency can work properly in the design.
Since 2 clocks on the same port cannot work physically at the same time, the paths between these 2 clocks should be ignored.
The below constraint should also be added to avoid unreasonable data path analysis:
Ex:  set_clock_groups -physically_exclusive -group [get_clocks clk1] -group [get_clocks clk2]
drjohnsmith
can you share a link to the doc and reference please
dharpeer
Hey,
Thanks for this, so basically this way its possible to detect when either is applied?
dharpeer
Hey,
This was a tutorial on timing constraints priority.
hongh
Hi, @dharpeer ,
drjohnsmith
You said it was a xilinx one
can you post a link please, sounds interesting
