rkfournier
Need ideas for resolving pesky hold violations
I have an Artix-7 design where Implementation consistently results in hold violations on three end-points within a single clock domain. The worst case violation is -0.262ns and the total is -0.786ns. I have already found and tried the ExploreWithAggressiveHoldFix Physical Optimization option, which had no effect.
What else should I try?
rkfournier
Hi Avrum,
   I just stumbled on a mistake in my logic where the clock was also being used as the reset within a VHDL process. The three points that failed were the three registers affected by this mistake. It was identified in the Synthesis warnings which I had missed. Once this mistake was corrected the design met all timing.
Hello RK,
-retiming option during synthesis?
Guy
avrumw
Expert
Expert
That is extremely unusual. Hold times within the same domain are generally limited by the fact that the clock skew is constrained, and since the clock skew is relatively small, the tool almost never has problems fixing them.
Violations of 0.25ns after the tool has done it's best to fix them don't really make sense...
Can you post one of the failing paths - the complete timing report, including the source clock delay and destination clock delay. Even if the startpoint and endpoint are on the same static timing analysis clock (as reported by the tool), you can still have structurally different clock insertion paths which can cause unusual skew (and hence hold violations).
Avrum
rkfournier
Hi Avrum,
