Observer silvaurus
Negative Hold Slack for Custom IP
Hi!
I'm kinda new to FPGA design. The project I'm working on is a peripheral AXI IP. When I synthesize the IP alone, it reports tons of negative hold time slack. Whilie if I incorporate this IP into block design, sythesis returns all positive slacks.
The constraints I gave for the IP are just (1) defining clock e.g. 10ns (2) input delay for all_inputs 2ns (3) output delay for all_outputs 2ns.
I can pretty much guarantee that the internal logic of my design makes sense, and have been synthesized using Design Compiler and ASIC library.
Could you help me figure out the reason for those negative hold time slacks? Thank you so much!
Visitor peterk
Re: Negative Hold Slack for Custom IP
If the negative hold slacks are in the same clock domain, then you can ignor them in the synthesis timing report. Implementation normally will fix them.
Peter Kwan, Senior FPGA Engineer
Designlinx Hardware Solution, Inc
Hi @silvaurus
can you try running report_qor_assesment and report_qor_suggestions from your tcl console.
please have a look at the following to know more about report_qor_suggestions
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug906-vivado-design-analysis.pdf#page=153
--Suraj
Can you attatch the timing report file?
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Visitor peterk
