New clock constraint required when clock net changes name at module port?
Is a new clock constraint required when a clock net changes name when entering a module port?  For example, if a clock net named 'system_clk' that enters the 'clock' port of a module, is a create_derived_clk constraint required?  Or does the timing analyzer confer the characteristics of 'system_clk' onto 'clock'?
For example:
module UserModule (
    input    wire clock,
    input    wire reset_n,
    output reg   sig
UserModule my_module (
    .clock     ( system_clk    ),       //  <=  is a new constraint needed for 'clock'
    .reset_n ( system_reset ),
    .sig        ( signal_out      )
Thanks!
No
No
Thanks.  Makes sense that a module entry name change shouldn't require a new constraint, but since I couldn't find it explicitly stated I thought I should ask.
Much appreciated!
