pgrangeray
Non periodic signal as clock source : Error
Hello everybody!
I'm back with new trouble!
I am now with the timing constraints. First time...
I can't find the good answer to my problem :
A module (including a MIG) generate an output signal used as input clock of a counter (increment every rising edge).
This signal, used as clock, isn't a clock! Sometimes it can be low during multiples seconds.
So, the timing report say "No clock".
Is there a way to ignore timing constraint s in this case, or my code is very very bad :) ?
Paul
avrumw
Guide
Guide
Yes. It is.
In synchronous digital design (particularly in FPGAs) we don't do this.
If you want to increment a counter on a rising edge of an aperiodic signal, then you:
  - sample the aperiodic signal on a "fast enough" clock
     - this needs to use a synchronizer to ensure the signal is not metastable
     - this will also need a timing exception
  - use the synchronized version of the signal to determine when it has transitioned from a 0 to a 1
     - it it was a 0 on the last clock cycle, and is a 1 on this clock cycle then it experienced a rising edge
  - run the counter on the same high speed clock as the synchronizer
     - increment it on the clock cycle where the 0->1 transition was detected
Now your entire system runs on a single clock. If you specify a create_clock for that clock input, your design will be timed correctly.
Avrum
avrumw
Guide
Guide
Yes. It is.
Avrum
pgrangeray
Hi @avrumw
Thank you for you answer.
It was the solution i wanted to avoid :) But it's the only good solution so... I will correct it!
