sardman
OFFSET constraints and multicycle paths
we need your support to set our timing constraints. As shown in this picture we have to drive a DEV by a DEV_CLK which is generated from the FPGA. The DEV Interface enable has also the same period of DEV_CLK. We tried to use these command lines in according with timing temporization:
NET "FEEDBACK" TNM_NET = "FEEDBACK";
TIMESPEC "TS_FEEDBACK" = PERIOD "FEEDBACK" 20 ns HIGH 10 ns;
TIMEGRP "DEV_in" OFFSET = IN 19 ns AFTER "DEV_CLK";
TIMEGRP "DEV_out" OFFSET = OUT 4 ns BEFORE "DEV_CLK"
with also,
TIMESPEC "TS_DEV" = FROM "DEV_IN" TO "DEV_IN": FEEDBACK*2;
The problem is that ISE couldn't accept the OFFSET command through an output clock signal and ignored a TIMESPEC command like that.
So, which is the right technique to set these kind of timing constraints?
jared.chen
Only external clock could be used in OFFSET constraints.Please see the WP237 for more information.
Here is a link http://www.xilinx.com/support/documentation/white_papers/wp237.pdf
Jared
Anonymous
Not applicable
Only Pad clock can be the reference pin for Offset out constraint
