Output constrain for synchronous data transfer (SDR)
I would like to interface my FPGA with an external synchronous element. The data is generated in a clock domain and I feed the same clock as the output clock to the external chip (SDR). I do not use a PLL to generate a phase shifted clock. I need to run at 100 MHz. I know the setup(1.5 ns) and hold time(0.8ns)  requirements of the external device.
I assume I should use maximum/minimum output delay constrain but I am not sure if I calculated it properly.
output maximum delay value = maximum trace delay for data+  setup time of external register - minimum trace delay for clock
output minimum delay value =  minimum trace delay for data - hold time of external register - maximum trace delay for clock
As an example, I assumed minimum trace of clock and data to be 0.2 ns and maximum trace of clock and data to be 0.5 ns.
Then I get output maximum and minimum delay to be 1.8 ns and -0.8 ns.
It would be great if someone can validate my calculations and suggest any other alternatives for constrain if any.
Paul
Guide avrumw
Guide
Re: Output constrain for synchronous data transfer (SDR)
No, this isn't right...
The modified setup time is the original_setup_time + maximum_data_delay - minimum_clock_delay
The modified hold time is          original_hold_time + maximum_clock_delay - minimum_data_delay
So your modified setup time is 1.5+0.5-0.2= 1.8ns
Your modified hold time is 0.8+0.5-0.2 = 1.1ns
So your constraints are
set_output_delay -max 1.8
set_output_delay -min -1.1
As a general rule nothing gets better in the case where there is uncertainty - uncertainty always hurts. In this case, you have 0.3ns of uncertainty between the clock and data routing, so this costs you 0.3ns of extra hold requirement and 0.3ns of extra setup requirement.
Avrum
Guide avrumw
Guide
Avrum
