jprovidenza
Voyager
Voyager
PAR 12.2 vs Trace 12.2 report disagreements
I'm using ISE 12.2 on a Spartan 6 design and have been seeing numerous  bogus
outputs from the Trace program.  The latest is PAR vs Trace.
Here's info from the PAR report:
Timing Score: 0 (Setup: 0, Hold: 0, Component Switching Limit: 0)
Routing: Completed - No errors found.
Timing: Completed - No errors found.
From the TRACE report:
Timing errors: 16  Score: 37543  (Setup/Max: 0, Hold: 37543)
Is anyone else seeing this type of discrepancy?  I'm also seeing problems that Trace treats
some signals as unconstrained that are clearly constrained.  The signals tend to involve either
BRAMS or Distributed RAMs.
John Providenza
htsvn
It looks as not to be working as intended, please file a webcase with Xilinx Technical Support.
Thnx
ywu
If you run trce with -u (report unconstrained paths), it will report hold violations on unconstrained paths. Take a look at the .twx from trace to see if that's the case.
Regarding distRAM showing up in unconstrained path report, check http://www.xilinx.com/support/answers/35881.htm to see if it's applicable.
John Providenza
Cheers,
Jim
jprovidenza
Voyager
Voyager
Jim -
I always run with the -u option so I can resolve unconstrained paths.  I have constraints i my
UCF file that *should* tig some ot the distRAM paths, but TRACE only applies it to some of
the paths.
Right now I see 3 problems with PAR vs TRACE in the 12.2
1) they disagree on the timing results
2) trace does not porperl y apply UCF constraints to distRAM paths
3) trace reports some paths as unconstrained that actually look to be
properly constrained.
I've opened a Webcase to see what resolution is suggested.
This is very disappointing.  How can you do a correct design when the tools lie to you?
John Providenza
endab
There is a known issue with DRAMs not been picked up correctly by TNM constraints. Please see the following:
The other issue with the Timing Score not been 0 when the -u option is used. I filed a CR aginst the tools and will provided feedback to this tread once I have more information.
jprovidenza
Voyager
Voyager
Yes, I'm adding the kludges suggested by the AR358881 to see if they help.  That problem was
planned to be fixed in 12.2 according to the AR.
I suspect XIlinx should update the AR to report that the distRAM timing bug is not yet fixed.
John P
jprovidenza
Voyager
Voyager
The TPSYNC kludge suggested by AR358881 only partially works. I added lines like:
INST "*/u_phy_rx_fifo/Mram_pause_fifo_mem*"   TPSYNC = "pause_ram";
TIMESPEC "TS_pause_ram_2"        = from FFS to   "pause_ram" 7.7 ns datapathonly;
But I still get unconstrained paths like:
Timing constraint: Unconstrained path analysis
 1462 paths analyzed, 1462 endpoints analyzed, 0 failing endpoints
 0 timing errors detected. (0 setup errors, 0 hold errors)
 Minimum period is   7.805ns.
Paths for end point u0_channel/u_phy_rx_fifo/Mram_pause_fifo_mem2_RAMB (SLICE_X18Y38.BX), 1 path
Delay (setup path):     7.805ns (data path - clock path skew + uncertainty)
  Source:               u0_channel/rx_d_1 (FF)
  Destination:          u0_channel/u_phy_rx_fifo/Mram_pause_fifo_mem2_RAMB (RAM)
  Data Path Delay:      7.547ns (Levels of Logic = 0)
  Clock Path Skew:      -0.039ns (0.696 - 0.735)
  Source Clock:         u0_channel/rx_clk rising at -0.771ns
  Destination Clock:    u0_channel/rx_clk rising at 7.129ns
  Clock Uncertainty:    0.219ns
In addition, TRACE reports
Timing constraint: TS_pause_ram_2 = MAXDELAY FROM TIMEGRP "FFS" TO TIMEGRP
"pause_ram" 7.7 ns         DATAPATHONLY;
 0 paths analyzed, 0 endpoints analyzed, 0 failing endpoints
Sigh.
John Providenza
endab
The issue with the Timing Score difference in PAR and TRCE is expected. I created AR 37292 for this with the following contents:
“When you run a timing analysis and report unconstrained paths with the -u switch I see a timing score due to hold violations. Is this correct?
Yes this is correct and expected. The unconstrained timing report may include hold errors that are not explicitly covered by user timing constraints and this is designed to alert the end user that these unconstrained paths have hold violations. Please see the following:
http://www.xilinx.com/support/answers/31881.htm
Par implements the design to the end-user's timing constraints, and does not perform analysis on unconstrained paths, hence the zero timing score in par. Under these circumstances trce without the unconstrained option will also get a zero timing score, reflecting only the timing constraints explicitly specified for implementation. But when the unconstrained analysis is run then any failures will contribute to the timing score.”
I hope this explains the situation.
The issue with the DRAMs not been grouped should be worked on seperately and I have a case on this.
xingzhe
this i think is caused by misuse of clock in your design, for example, maybe you have data path between two unrelated clock, or else your clock is using regular routing resource which leads to too much skew on clock.
jprovidenza
Voyager
Voyager
No, the problem was not a design problem,  it was caused by a bug in the Xilinx s/w.
They reproduced the problem and sent me a patch file that updated some of their files. After
installing the patch, the timing tools started analyzing all the paths and gave sensible results.
John Providenza
