shaikon
Voyager
Voyager
Position on the "edge" switch in timing constraints
Are the the following 3 constraints 100% equivalent ?
set_input_delay -min -0.8 -clock_fall -clock [get_clocks some_clock] [get_ports {some_port}]
set_input_delay -min -0.8 -fall -clock [get_clocks some_clock] [get_ports {some_port}]
set_input_delay -min -0.8 -clock [get_clocks some_clock] [get_ports {some_port}] -clock_fall
klumsde
Arguments:
-clock <arg> - (Optional) Indicates that the input delay is relative to the
specified clock. By default the rising edge is used. However the
-clock_fall argument can be used to indicate that the falling edge should
be used instead.
-reference_pin <arg> - (Optional) Specifies that the delay is relative to
the active edge of a clock appearing on the specified pin or port rather
than a clock.
-clock_fall - (Optional) Specifies that the delay is relative to a falling
edge of the clock rather than rising edge.
-rise - (Optional) Specifies the input delay applies to rising transitions
on the specified ports. The default is to apply the delay for both rising
and falling transitions.
-fall - (Optional) Specifies the input delay applied to falling transitions
I expect the first and the 3rd constraint are the same. the problem with the 2nd one is that it is using the -fall option which seems to say that the input delay is only valid for falling transitions on the signal...
shaikon
Voyager
Voyager
This is what avrum had to say about the subject:
https://forums.xilinx.com/t5/Timing-Analysis/Timing-Analysis-about-input-delay/td-p/786262
search for the string "we do not select the check" in the link.
