thulinn
Post Implementation Simulation - BRAM data out one cycle earlier in Vivado 2019.2
Behaviour, Post-Synthesis (both functional and timing) and Post-Implementation (functional) simulation proves that data comes out in next cycle after latching the address. However, Post-Implementation (timing) simulation shows the the data come out as soon as the address is latched. Did I do something wrong or it is a bug in the simulator?
thulinn
Now I know why post-implementation timing is not working. It is because I happened to use one controller to drive address stroke to a few BRAMs which causes some BRAMs received address strokes incorrectly due to the routing delays. Assigning dedicated controller for each BRAM solves the issue.
calibra
Simulation is correct.
Data change on the clock rising edge when CED = '1'.
CED starts one cycle later in post-implementation timing maybe due to a delay in a synchronous reset.
== If this was helpful, please feel free to give Kudos, and close if it answers your question ==
thulinn
I understand the data appears at the rising edge but the data should be from the address of the previous rising edge.
in synthesis simulation:
clk >address >data
01 >addr000 > 0000 (initial resets value)
02 >addr001 > cc5392b3 (data from addr000)
02 >addr002 > ac596640 (data from addr001)
However in post-implementation simulation
clk >address >data
01 >addr000 > cc5392b3 (data from addr000)
02 >addr001 > ac596640 (data from addr001)
02 >addr002 > ab75e7c2 (data from addr002)
that is strange!
calibra
I don't agree.
In the funcional simulation the first clock rising edge with CED=1 is at 140.100 ns and ADDR=0.
markgraf
It is looks in your simulations, you are observing the clock at it's source. It also looks like there may be a delay in the clock getting to RAM. Therefore the rising edge is getting there slightly after the address changes.
Steve Markgraf - Distinguished FPGA Design & Support Engineer E5-E
www.designlinxhs.com
thulinn
I assume it is the post-implementation timing simulation issue. In one of my testings on 18k BRAM, DOUTBDOUT[15:0] is one clock ahead of DOUTADOUT[15:0] despite there is only one common clock going into 18k BRAM. It does not make sense at all. I attached the implemented schematic in this post.
calibra
If you have found a bug, post a project that shows it.
thulinn
calibra
Next time check the timing with "report_timing" before simulate.
