Pulse width timing violation even with the same CLOCK_DELAY_GROUP
hi,
for OSERDES3. I connect one  BUFG  for the output of MMCM, then connect to CLK port of oserdes.
BUFGCE_DIV to the output of MMCM, then connect to CLK_DIV of oserdes.
In the constraints, I add them to the same CLOCK_DELAY_GROUP.
set_property CLOCK_DELAY_GROUP MUX_and_BUFGCE [get_nets u_NV_hstdm_sourcesyn_send/u_NV_HSTDM_ga10x_sendclk/inst/clk_oserdes]
set_property CLOCK_DELAY_GROUP MUX_and_BUFGCE [get_nets u_NV_hstdm_sourcesyn_send/u_NV_HSTDM_ga10x_sendclk/inst/core_clk]
But I still see the pulse width timing violation if I improve the div_clk to 50Mhz and CLK(serial_clk) to 200Mhz. (clock ratio 1:4).
Why? How to solve this?
Historian
Historian
Re: Pulse width timing violation even with the same CLOCK_DELAY_GROUP
Take a look at this post on the same problem - it appears that the CLOCK_DELAY_GROUP isn't sufficient.
Avrum
hi,seems I still met hold timing violations after clock_root constraints were added.
my related constraints are:
create_generated_clock -name {clk_oserdes} [get_pins {u_NV_hstdm_sourcesyn_send/u_NV_HSTDM_ga10x_sendclk/inst/mmcme3_adv_inst/CLKOUT1}]
create_generated_clock -name {clk_oserdes_div} [get_pins {u_NV_hstdm_sourcesyn_send/u_NV_HSTDM_ga10x_sendclk/inst/clkout1_div_buf/O}]
##create_generated_clock -name {core_clk} [get_pins {*/u_NV_HSTDM_ga10x_sendclk/inst/clkout1_div_buf/O}]
set_property CLOCK_DELAY_GROUP MUX_and_BUFGCE [get_nets of [get_pins {u_NV_hstdm_sourcesyn_send/u_NV_HSTDM_ga10x_sendclk/inst/mmcme3_adv_inst/CLKOUT1}]]
set_property CLOCK_DELAY_GROUP MUX_and_BUFGCE [get_nets of [get_pins u_NV_hstdm_sourcesyn_send/u_NV_HSTDM_ga10x_sendclk/inst/clkout1_div_buf/O]]
set_property USER_CLOCK_ROOT X2Y3 [get_nets of [get_pins {u_NV_hstdm_sourcesyn_send/u_NV_HSTDM_ga10x_sendclk/inst/mmcme3_adv_inst/CLKOUT1}]]
set_property USER_CLOCK_ROOT X2Y3 [get_nets of [get_pins u_NV_hstdm_sourcesyn_send/u_NV_HSTDM_ga10x_sendclk/inst/clkout1_div_buf/O]]
Historian
Historian
Your commands are not correct - I suspect they are just typos when you pasted them here. In the set_property commands, the should be:
set_property CLOCK_DELAY_GROUP MUX_and_BUFGCE [get_nets -of [get_pins {u_NV_hstdm_sourcesyn_send/u_NV_HSTDM_ga10x_sendclk/inst/mmcme3_adv_inst/CLKOUT1}]]
your commands are missing the dash before the word of
Other than this, I don't see anything obvious. If this still doesn't fix the timing violation, I have no more suggestions for you... This seems to be a problem in UltraScale - the combination of the on-chip variation pessimism of the tool with the very tight skew requirement between CLK and CLKDIV of the ISERDES/OSERDES makes the pulse width check impossible to meet (at least under some circumstances).
It is up to Xilinx to figure out where to go from here - if you have followed the XAPP note in the referenced post (and it looks like you did) and you still fail timing, then there is no solution to this problem...
Avrum
hi,Avrumw,
yes, you're correct, it's just a typo here.
But I still get the pulse width timing violation here. even with same clock_delay_group and clock_root.
Waiting for guys from xlinx to help on this.
