whisper
Question of delay time on same hardware description
--------------------------------------------DIVIDER-----------------------------------------DIVIDER-------------------------------------------------
Here is the question
Why the same hardward description get the different delay?
I just changed  prefix to the lower case but why
I was used the Xilinx ISE 10.1and get the Synthesis report of Design summary
I confused for a long time
markus.offergeld
by changing the name you will also change the order of snythesis/mapping and you will end up with a different map/place and route. Note that you not only changed the case but the name of the module itself.
Let asume the order is alphabetical and you have other modules/blocks in your system. If you module comes first it will use FPGA placement at site X. If your module comes second however, then site X might have been already used -> your module will use a different placement -> routing and timing becomes different.
This is normal and there is no need to worry about this unless your final timing report is failing
Regards Markus
viviany
First, although the two sets of code are only of different case, they are DIFFERENT CODES. It won't suprise me that they produce different synthesis result - saying netlists and Synthesis timing results.
Second, the two delays in your examples are similar - 9.157 and 9.882. This difference between the two at the Synthesis stage is reasonable as the Synthesis timing analysis is just estimated.
You don't need to struggle with the XST synthesis timing analysis result. Go straight to the post-MAP or post-PAR timing and those are more meaningful for you to do timing closure.
-Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
markus.offergeld
Regards Markus
hj
Could you please compare the post implementation timing in both the cases?
Check the difference. Since exact timing with routing delays can be observed after implentation.
Harry
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
