Router estimated timing not met. - Neagtive WNS and TNS
I am working a 3D rendering project on Kintex 7 board and I face a problem with timing.
After I run Implementation I see this error.
I can generate the bistream ans test it but it seems that it is static. I mean that something is going wrong with the clock.
Also, i saw that WNS and TNS are negative .
Kintex7 Uses differential clock input 200MHz and for my implementation I need two clocks, one for I2C (100MHz) and one for the rest implementation (150MHz). I have done this using IP Clocking Wizard. In the XDC i use this for clock.
I have ran simulation and all work fine. So I think that the problem is with clock.
I would appreciate any response. Thanks in advance.
-Fotis
Fotis Pegios
Senior Undergraduate Student
Department of Electronics and Computer Engineering
Technical University of Crete, Greece
http://fpegios.blogspot.gr/
fpegios92@gmail.com
Tel.: (0030) 694 464 7289
Tags (3)
Guide
Guide
The problem is with your architecture.
The first failing path goes combinatorially through two DSP48E1 cells. While I can't tell the operation itself, I suspect it is doing a multiply or multiply/accumulate of a large value (more than 25x18 multiply). After the DSP48 cells, there are still 6 LUTs of additional processing before the result hits a flip-flop.
You are trying to run this at 6.66ns. This path has way too much logic to run at this speed... You need to re-evaluate your architecture and add at least one (I would highly suggest more) pipelining to this path. Without changing your RTL code, it is unlikely that you will get this design to meet timing.
Avrum
HI @fpegios
From the timing report, obviously your desing has many setup timing violations(5599).
Always ensure the performance of your design from Post-implementation timing simulation (not just behavioural simulation) and only then proceed to generate the bitstream.
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
Hi Bharath,
Thanks for the quick reply. How can I avoid that problem? I s there a certain way?
Fotis Pegios
fpegios92@gmail.com
@nagabhar
Fotis Pegios
fpegios92@gmail.com
HI @fpegios
Can you please share your timing report?
Also please confirm that your design is indeed not working as expected in post_implementation timing simulation itself.
Bharath
Hi @nagabhar
Here is the timing report.
Fotis Pegios
fpegios92@gmail.com
Guide
Guide
Avrum
@avrumw @nagabhar
Thanks, I have figured out that problem! How can I run post place and route simulation on Vivado?
Fotis
Fotis Pegios
fpegios92@gmail.com
Hi @fpegios,
Please give kudo(star on the left) to answer that helped you to find solution.
For Post place and route simulation please follow the following steps.
1. Implement Design
2. Navigate to Flow Navigator->Simulation
3. Click on Run Simulation. You will see the option for Post Implementation Functional as well as timing simulation.
Attaching a snapshot for your reference.
Arpan
Arpan
Hi @arpansur
Fotis Pegios
fpegios92@gmail.com
Hi @fpegios,
I mean Flow Navigator. See the screenshot.
After implementation complates. Go to simulation. See the screenshot attached in my previous post.
Arpan
Arpan
Hi @fpegios,
Are you able to proceed with post-implementation simulation now?
Please let us know if you are facing any difficulty in understanding the flow.
Arpan
Arpan
@arpansur
I have run the post implementation functional simulation but it too slow. If I face any difficulty with that I will post again.
Thanks a lot!!
Fotis
Fotis Pegios
fpegios92@gmail.com
Hi @fpegios,
Please start a new thread in Simulation and Verification Community if you are getting any simulation issue to target the right audience.
Arpan
Arpan
Alright @arpansur. Thanks for the help!
Fotis
Fotis Pegios
fpegios92@gmail.com
