joe306
SDC Input and Output Delays
Hello, I would like to ask the forum members for their comments on my values on Input Delay and Output Delay. Is my trace delay min/max seem okay?
Thank you
Joe
viviany
These values represents the actual timing data on your board.
Where do these numbers come from?
We need the details to see if the values are correct.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
viviany
-vivian
