03-13-2013 02:35 AM
I am using a SPARTAN6 speed grade 3 and there is a high speed SDR SRAM In my board as well. I've used DCM to generate clock for the logic and out to SRAM.
I set timing constraint but the max frequency I achieved is 125 MHz. If I increase the output clock of DCM to 150 MHz I have timing constraint error: "Slack in some nets is -3.447ns."
How can I increase the max frequency?
what should I do exactly in timing constraint?
How can I set constraint on DCM output?
Amin
03-13-2013 04:52 AM
You should probably read the Xilinx guides on Timing Constraints first.
However, you should ALWAYS specify a PERIOD constraint for your input clock signal. It sounds like you have done this (or at least tried). You can use the constraints editor for this or you can add a couple of lines to your UCF, similar to this:
NET "input_clock" TNM_NET = "tnm_input_clock";
TIMESPEC "TS_input_clock" = PERIOD "tnm_input_clock" 125 MHz;
There are other options for duty cycle and input jitter but look them up later. Hopefully you can see that the above lines specify a frequency of 125 MHz for your input clock. If you wish to reconstrain your design to a higher (or lower) INPUT clock frequency, you should edit the example given above accordingly.
You don't normally need to add constraints to DCM outputs. the tools are smart enough to figure out the required details from your input constraint and the configuration of the DCM itself.
If, after place and route static timing analysis, you have timing errors (similar to the one you quoted), you will have to examine the failing path(s) yourself and decide how best to proceed to help meet timing. This may include (but is not limited to) redesigning your code, pipelining, optimising resources, etc. The Xilinx tool SmartXplorer can help in some timing cases but is no guarantee.
Howard
03-13-2013 05:36 AM
Yes, I already used priod constraint like you said. but I was thinking there are some other solution that I dont know. So, could I cunclude I can not achieve more performance by Spartan6?
I have another question: How can I determine Input bus (for example 32 bit) arrive ot the their corresponding FF at the same time? In other words, is there any constraint to force eqaual length routing for the BUS from input pad to FF or FF to output pad?
I read the timing constraint document but I could not find any appropriate constraint.
I tried to depict my problem:
Amin
03-13-2013 05:54 AM - edited 03-13-2013 05:55 AM
Frankly, I would conclude that your design needs altering. Without knowing exactly what timing errors you get, or exactly what your code is trying to do, it is pretty difficult to suggest a further solution.
I would have expected that an FPGA-SRAM interface could run faster than 150MHz, though.
It isn't necessarily a case of getting them to their respective FF at THE SAME TIME that is important, though, is it? This is a synchronous interface - you need to get them to their respective FF for THE SAME CLOCK EDGE. This is quite a difference.
Assuming that your board has an excellent layout (and therefore the track delay is near enough the same for each data bit) then you need to constrain the input interface. You can do this by using the OFFSET constraint and relates to the setup and hold specifications of the external device, something like this:
OFFSET = IN 6ns VALID 10 ns BEFORE "sram_clock" RISING;
where "sram_clock" is the system synchronous clock driven from the FPGA to the SRAM. This example shows that the data from the SRAM will be valid 6 ns before the rising sampling clock edge and will remain valid for 10 ns. This constraint will force the tools to place the sampling FFs in such a way within the device that the constraint is met, thus your data capture is OK.
You will, of course, have to check the setup and hold requirements of the data from the SRAM data sheet.
You should also probably constraint the data going the other way (i.e. writes to the RAM), also using the OFFSET constraint but with the OUT keyword. Again, check the constraints and timing closure guides.
P.S. I couldn't see your diagram, so I guessed a bit.
03-13-2013 06:49 AM
thanks for complete answer and sorry for diagram missing. I just depicted my problem not my all design.
Can I use internal clock(s_sclk in the picture) for offest constraint? if yes, I think my problem has resolved. based on constraints editor( and also document) I had realized just input clock can be used for this.
You know what: I had set constraint to force FF to be placed in IO block in order to overcome the same length problem I mentiond before. And so, I was reducing the flexibily of placemnet and as a result bad timing. If I can use offset as you said, I'll remove the FF in IOB constraint.
thanks alot.
Amin
03-13-2013 07:06 AM - edited 03-13-2013 07:07 AM
Putting FFs in the IOB can be a good idea, both for timing and size related issues.
The internal clock (s_clk, in your case) should not be used for the OFFSET constraint. As weird as it may sound, the OFFSET constraints relate to the INPUT clock ONLY. Like I mentioned before, the tools are clever enough to work out related timing parameters for setup and hold for downstream (i.e. DCM generated) clocks.
-- edit
P.S. Make sure you follow correct clock forwarding techniques for the clock to the SRAM.
-- end edit
03-14-2013 03:35 AM
Thats is difficult to understand how tools can handle it. What should I do? for example, if input clock period is 20 ns and derived clock (s_clk) is 5 ns then how should I set the OFFSET?
suppose I need the below constraint:
OFFSET = IN 1 ns VALID 5 ns BEFORE "s_CLK" RISING;
so is that correct to define:
OFFSET = IN 1 ns VALID 5 ns BEFORE "input_clock" RISING;
or I should use proporion of 4 (20/5)?
thanks
Amin
03-14-2013 04:57 AM
You are considering data IN to the FPGA. The setup and hold times will be dependent on the data source, not the clock entering the FPGA.
Let's take an example. Your input clock is 50 MHz but your DCM clock that drives the SRAM is 200 MHz clock (a period of 5 ns). Let's assume the SRAM can output data from the edge of its clock in, say 3 ns. That gives a further 2 ns of setup before the next SRAM clock edge. If the SRAM maintains valid data until the next bit of data is output, that's a full cycle of the SRAM clock, so I would consider the correct OFFSET constraint to be:
OFFSET = IN 2 ns VALID 5 ns BEFORE "input_clock" RISING;
So we are using the input_clock EDGE for the constraint. It doesn't matter what the input_clock period is because the tools know, from your design, that the capture clock (s_clk) is related to the input clock and will report the timing based on this relationship.
You should check what the data source (SRAM) states for its own clock-to-out times and how long the data remains valid.
03-14-2013 05:11 AM
I appreciate you for your complete and clear reply.
Amin
