amin_8460
Specifying Timing Constraints in XST
In the UG612, it has been mentioned we can specify timing constraint in HDL or ucf file. Is there any diffrence between these two specifying?
If yes which one is better?
thanks
Amin
bassman59
Historian
Historian
@amin_8460 wrote:
thanks
Amin
Always specify constraints in the UCF. They don't belong in the source code.
sampatd
If you are specifying the constraints in the HDL, and wish to change them during the design cycle - you will need to re-synthesize the design. Whereas, constraints specified in a UCF file taken in by the tool in the Translate(ngdbuild) stage, which is a post synthesis step, allow you to use the original netlist (ngc) thereby obviating the need to synthesize again.
