caslaba
Speed of a circuit without I/O
I am designing a interior circuit that has no IO connections. ( I have unchecked" Add IO Buffers" from synthesis options and "trim unconnected signals" from map properties )
The circuit flow is such that; ( only one clock exists)
INPUT => flip flop => Block RAM =>  Combinational Logic => Flip Flop => OUTPUT .
I must take the max clocking speed with regarding the circuit as an interior FPGA design with no IO delay.
bassman59
Historian
Historian
you're going backwards.
You set a timing constraint based on the target period you're trying to achieve, and the tools work to meet that constraint.
Without a constraint, the tools will do the easiest/laziest thing, which may or may not be the fastest possible path.
hasaney
I don't understand the going backwards WHY?
If i set a constraint, CLK speed is shown. However without a constraint on CLK, there is no timing report about max frequncy of CLK. In general which I saw until now, P&R report gives to CLK speed without introducing a CLK constraint.
bassman59
Historian
Historian
@hasaney wrote:
AGAIN: Without setting a constraint, the tools will do whatever's easiest. They will report the clock frequency which results.
If you are interested in actual performance metrics you need to set a timing constraint.
