Synthesis show timing summary numbers in Design Runs tab
   I am trying to get Synthesis to show timing summary numbers similar to how implementation does by default.   I updated the report stategy for Synthesis to include report_timing_summary, but still don't get the numbers to show up in the Design Runs tab.
   Does somebody know how to make this work?
Tim
Can somebody from Xilinx please verify if this is possible or not?
Tim
@tim_severance it won't show automatically. It works differently with Synth.
You can open Report Timing Summary from Flow navigator after running synth.
hemangd
