Visitor pregache
Temperature used by STA
Hello, i have set my projet with device xc7a35tfgg484-1.
The "select device" screen does not show a min/ref/max temperature.
The STA runs fast and slow corner cases. Question is: what are the min/max temperature assumptions (in the speed file) ?
Said otherwise, does this setting apply to commercial, industrial or other grade device ?
Best regards
Pascal
Re: Temperature used by STA
You can refer to the below AR:
https://www.xilinx.com/support/answers/38221.html
For Industrial device, the worst condition is -40 ~ 100 ℃;
For Commercial device, the worst condition is 0 ~ 85 ℃;
For the new device(Ultrascale or Ultrascale +) , you can select I or C for your device.
It's expected that the temperature is not shown in the timing report.
The min/max temperature is defined in the spec of the device.
For Commercial device: 0 ~ 85 ℃;
For Industrial device: -40 ~ 100 ℃;
Speed grade shows how fast the device can run (with different speed files)
Visitor pregache
Hello. Yes I understand that.
The question is: is the device xc7a35tffg484-1 (in vivado select device menu) corresponding to a commercial or an industrial device ?
The select device screen does not show any temperature value and therefore the tool/speed file shall assume something.
Pascal
Hi Pascal,
You cannot select temperature. As Hong mentioned there is high and low temperature correspond to each FPGA grade.
Tools does the analysis over the PVT (4 process corner) analysis and report the worst case timing report.
Upto V5 there is possibility where user can control the Temperature and Voltage but with lather FPGA this feature was deprecated. Now user do not have any control to change the values to specific temperature and voltage.
If your design is meeting timing (0 violations) then it is expected to work seamlessly over the temperature and voltage range correspond to FPGA grade.
I hope this information will be helpful.
Yash
Assuming all the constraints are correctly set, the bit for xc7a35tffg484-1 without timing violation can work on BOTH commercial and industrial device.
That means in their own temp range, they can both work.
Visitor pregache
OK, thanks.
Is this mentionned somewhere in the tool or documentation (could not find anything) ?
Does it mean that the Vivado tool assumes the worst case condition (-40°C / 100 °C) ?
Pascal
Those Answer Record may be helpful to understand this:
https://www.xilinx.com/support/answers/4235.html
https://www.xilinx.com/support/answers/2945.html
Those are for ISE Timing Analyzer tool. But Vivado is of the same theory.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Visitor pregache
That clarifies all. Thanks.
