Timing Analysis - Xilinx ISE 14.7/Spartan 6 FPGA
We are working on a project which involves sampling ADC data, and sending out the sampled data as UDP packets using Spartan 6 FPGA. We used TEMAC core, and an external PHY, the design is FPGA proven.
We haven't done any timing analysis for the design yet, and wanted to do the same. But are clueless, on what has to be done, and how to go about it. Any suggestions on where to start would be a great help for us. We using Xilinx ISE-14.7.
Manoj
1. use constraint in your design
http://www.xilinx.com/itp/xilinx10/books/docs/timing_constraints_ug/timing_constraints_ug.pdf
add constraints in your project ucf file
2. run implementation and check timing report. your dsign should meet timing
Thanks and Regards
Balkrishan
Guide
Guide
Unfortunately, this is not something that can be "taught" on Forum posts. The concepts of static timing analysis and constraints are complex...
If you are serious about learning this, Xilinx offers classes through their network of Authorized Training Providers (ATPs). However, you would need to find an ISE based classes. The complete set of classes for ISE are these:
Essentials of FPGA Design
Designing for Performance
Advanced FPGA Implementation
Static timing analysis and constraints are scattered throughout the three classes, intermixed with tool flow, device architecture, and more advanced concepts...
Avrum
Thanks and Regards
Balkrishan
@manojhan
You can use ISE constraints editor and the constraints will be saved in a ucf file. Refer http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/pce_c_overview.htm for more details
Sravanthi
Thank you everyone for your inputs. Will get in touch soon with more specific questions:)
Manoj
