Timing Analysis input clock default Jitter value
What is the default jitter and skew value used by timing analysis
  • I want to know if my input clock to the FPGA is OK.
  • I using input clock directly (Input Clock from MicroController > MRCC > BUFG > global clock tree
回复: Timing Analysis input clock default Jitter value
The text and GUI of the Report Timing command expose the breakdown of the clock uncertainty for each timing path.
e.g.
By default, Total System Jitter (TSJ) is set to 0.071 ns. If the clock is derived from MMCM/PLL, the Discrete Jitter and Phase Error will be calculated and accounted for automatically by tool based on the specified input clock jitter.
