alexgiul
Timing Constraint
I implement my design and with post-route simulation, I notice the signals are delayed:
for example I put the value x"5" on the bus, but in the simulation I see for a short time x"4" and after x"5"....
How can I solve it? is it normal?
bassman59
Historian
Historian
alexgiul wrote:
Wow, could you give us even less information?
ywu
 That is normal because the post-route simulation also includes delay data. Different bits in a bus will have different routing delay, that's why you will see an uncertainty window.
alexgiul wrote:
Cheers,
Jim
alexgiul
Hi bassma59,jimvu
you're right I forgot the design at home :).... Tomorrow I'll put the design...
I put the last timing simulation, the first "strange" transition is on value x"0" to x"5" but there are a lot...
 I try to explain the design: I have the Spartan3e starter kit and I'm sending an UDP packet.
The incoming clock is used to clocked the output signals (TX_DATA & TX_EN)
I have made 2 design, one the older works perfectly instead of this (you see the waveform and I check s the same as older) that never works.
Te first difference is on delay : for example in older design, the data on TX_DATA is placed after a small amount of time after the falling edge, instead of this new design, in which the data (the first bytes- after the delays increase) is place around the middle...
In the older design I haven't seen strange transitions or similar delays on single bit of the bus (ex TX_DATA)....
My question is: I try to create a group constraint on TX_DATA lines, and I put a OFFSET constraint to this group, I think ths constraint should affect the post-map & route simulation, instead I haven't notice anything,
what I would is place the start of "TX_DATA" he closest possible to falling edge, how can I do this???
I hope this infos help you
Thanks a lot for your support
alexgiul
I put the code...
into the folder "do" you will find the "do" file for simulation of post-place & map design
thanks a lot
