09-19-2019 03:42 AM
Hello!
I hope this finds whoever reads well! Before anything i'd like to say i'm new to HDLs, the design flow and the tools as well. As a result, I lack in generally most areas so please bear with me if i sound too "naive" .
To the question, I've been able to get my design through the RTL stage, and i'm able to simulate at the vhdl level and it works fine. Moreover, i've decided to move through the next stages of the design flow to implement the design on an FPGA. For the past 10 days, i've explored the IDE proceeding through the other steps of the design flow(sort of just "try-outs"), and read a number of guides that teach the next steps, even reading a number of posts from on here.
However, I stumbled upon timing analysis and definning timing constraints. I easily understood why they were needed but after proceeding to use the wizard to define them, i find i have little knowledge on how to evaluate the constraints themselves. Atm, i'm stuck at generated clocks, i've read and watched a lot of material concerning the subject but none seems to say how they evaluated the transformations into divides/multiplies and most importantly how they got the factors. Most of the examples were ripple counters btw and it was pretty straightforward in knowing what the next factor was. My circuit is larger and not made up of ripple counters. Atm i'm to define factors for 116 generated clocks, i naively followed the same principles from the ripple counter but fail the analysis every time.
As a result i'd like to ask for some enlightment on the subject! How exactly are the factors calculated? and btw in the video guides i watched, they seemed to be able to tell through inspection idk if i'm right but some pointers will really put my curiosity and frustration at ease. A reliable resource on the subject is welcomed too.
Thanks for helping this self-taught newbie in advance!!! and sorry if my punctuations and grammar suck(english is not my native, deeply sorry).
09-20-2019 08:29 AM
Also, does a single clock imply i shouldn't have as many generated clocks as i do now?
Absolutely!
If you have a single clock, then you should have a single clock only - no generated clocks.
I can see (quickly) that you do have a large number of what the system thinks are generated clocks, as well as latches. These are almost certainly coding errors - from your block diagram and from the general concepts of synchronous design (which I presume your processor is supposed to use) there should be no generated clocks.
So, rather than focus on constraints (which are not the problem here), you need to focus on why your coding is creating these "clocks". In your coding style you should have only
These are a very brief set of coding rules - if you stick to these you will get no generated clocks and no latches - and this is what you should be striving for.
Let's take a quick look at the list of generated clocks. The first one is pipe/pdatapath1/IDreg1/ID_RdE[4]_P/Q. This means that in the instance IDreg1, there is some code that says something like "always @(posedge ID_RdE)" or something like that (ID_RdE[4]_P is not the name of a flip-flop, so this is some combinatorial logic inside this module). This is a coding error. While it may functionally do what you want in simulation, this is not proper synchronous RTL design. RTL design (Register Transfer Logic) is a subset of HDL (Hardware Description Language - Verilog/SystemVerilog/VHDL); there are things that you can describe/define in HDL that are not synthesizable (hence are not RTL at all). Furthermore, within RTL, there are things that are not normal synchronous design practices (which are highly discouraged in an FPGA and even an ASIC).
You should probably read a good book on "coding using RTL" - unfortunately, I don't have a good recommendation (I'm sure others will suggest some).
Avrum
09-19-2019 10:40 AM
09-19-2019 11:01 AM
It's a little hard to understand your issue... You are talking about "factors" in generated clocks - are you referring to the relationship between the base clock and the generated clock (the -divide_by/-multiply_by/-edges relationships)?
Static timing analysis is static it depends purely on the structure of the synthesized design, not the functionality of the design - the functionality is analyzed via simulation which is dynamic. So, for example, if you have a counter generating a "terminal count", the tools only understand this counter from a structural point of view - it is a bunch of static timing paths that start at clocked elements and end at clocked elements and go through some combinatorial logic. The static timing analyzer does not know (or care) that it is a counter and has no idea that it is generating (for an example) a terminal count every 12 clock cycles - to know that, it would have to do simulation (dynamic).
Since it doesn't understand that the counter is generating a terminal count every 12 clock cycles, then if this terminal count (extending our example) drives the CE of a BUFGCE, it has no way of knowing the behavior of the output of the BUFGCE. If the BUFGCE were enabled all the time then the clock output of the BUFGCE would be the same rate as the input clock. But if the CE is asserted only every 12th clock (the output of the terminal count) then the output of the BUFGCE would behave like a clock with a frequency of 1/12th that of the input clock (and a very imbalanced duty cycle). Since it doesn't dynamically analyze the counter, it can't tell which it is (so it assumes the most pessimistic, which is that the CE is always enabled, and the output clock is the same frequency as the input clock).
That's why it is our job to define the generated clock. In this case we (the designer who designed the 12 cycle down counter and connected it to the CE of a BUFCE) know that the output of the BUFGCE is a decimated clock with 1/12 the input frequency, and we need to explain this to the static timing analysis tool. This can be done with
create_generated_clock -source [get_pins my_BUFGCE/I] -edges {1 2 25} [get_pins my_BUFGCE/O]
(the -edges {1 2 25} describes a clock that rises on the first edge of the input clock, which is also a rising edge, falls on the 2nd edge, which is the falling edge, and then rises again on the 25th edge, which is 12 full clock periods after the first edge)
So the relationship (in this case the -edges {1 2 25}) is determined because we (the designer) know what the system is doing (dynamically).
All that being said...
WHY DO YOU NEED 116 DIFFERENT CLOCKS?!?
Clocks are "special" things in an FPGA - they are handled with dedicated inputs, dedicated blocks to manage them, and dedicated nets to distribute them. These are all finite resources (depending on the architecture there can be as few as 32 global clock nets available). If you are trying to design something that needs 116 clocks, you are almost certainly doing something wrong (or at least going about it in an incorrect way)...
Avrum
09-20-2019 05:28 AM
09-20-2019 06:07 AM
that spectacular, esspecialy for a beginner.
Looks like you only have one clock though,
would it be worthwhile getting used to the tools and constraints on a simpler design ?
09-20-2019 08:11 AM
I'll do just that! Are there any designs you'd suggest to work on, to get used to the tools?
09-20-2019 08:29 AM
Absolutely!
Avrum
09-20-2019 09:15 AM
09-20-2019 12:23 PM
Ah!! this gives me ease and happiness all at once. It's been 8 days! At least now i know why! SUPER THANKS.
After migrating to vivado, the IDE prompted me about certain coding errors which didn't show up while i used the older IDE. Also the resource i used in studying HDLs, seemed to mix VHDL standards(Its an old book) and even had some unsynthesisable code. I found ways to get around the problems to get my design to work. I'm 100% sure i violated a lot of rules(if not all) which resulted into the problem i have now.
I'll find a better resource to study the appopriate coding styles/principles.
Thanks for making my day. :)
09-20-2019 12:35 PM
I use vhdl but not really sure what standard. My problem results from bad code. I'm pretty sure i have some latches too.
Now that i do know tho, i'll look for a better resource on the coding principles and fix the problem. The replies i got from on here were super helpful and put me in the right direction. Thanks a lot. It was good learning a thing or 2 about ASICs too!! thanks :)
09-20-2019 12:49 PM
09-21-2019 01:27 AM
09-21-2019 01:40 PM
hello!
i found the portion of the code where i had bad code. I decided to share my mistake just in case someone else (a naive beginner like me maybe, :) ) has a samilar problem in the future.
My problem resulted from the first 2 pipeline registers; they are configured to have dual resets (synchronous for flushing after data hazards and asynchronous at the start/bootup of the design). In an attempt to describe the hardware, the bad code i wrote created the extra clocks! I'm curious tho, about how the bad code translates into the extra clocks.
Anyways, I've added 2 shots showing one of those registers, before and after i fixed it. Thanks a lot again.
I'm left with figuring out I/O delays, i'm betting its no error to define delays on the I/Os ? It makes sense for the reset pin, however, a reason for the outputs will feed my curiosity. That is if my confident guess is even right. Thanks in advance.
09-22-2019 04:55 AM
09-22-2019 07:12 AM
09-22-2019 10:11 AM
09-23-2019 06:42 AM
super sorry, i got marked as spam again.
Thanks for the info on output delays btw.
(rest of the reply in the screenshot)
09-23-2019 08:17 AM
FPGas ar configuration , set EVERY register to a defined value.
so in VHDL if you do
signal fred : std_logic := '0';
Assuming your making fred into a register, then at configuraiton, register fred is set to 0.
