Visitor mbhardware
Timing Report: Requirement 0.0 ns - is that correct?
in my timing report I get some (hold) violations. I'm wondering that the Xilinx-Tool (ISE 10.1) requires 0.0 ns between two FFs.
In the report I found:
Requirement: 0.000 ns
I think the problem is, that I change the clock domain. The first FF is driven with the double clock frequency (clk2x) and the second FF with clk1x.
The clocks are derived by using a DCM and in the UCF I set a PERIOD constraint.
So my question:
- Is the requirement of 0.0 ns correct?
- Or in general, what is the meaning of this requirement?
- Can I define a constraint for example:
NET "interconnect_between_two_ff" MAXDELAY = 10 ns;
when period of clk2x is 10 ns and period of clk1x is 20 ns?
(Because sometimes I got in the report: "Requirement: 10.0 ns" and sometimes "Requirement: 0.0 ns"?!
Thank you
Instructor
Instructor
Re: Timing Report: Requirement 0.0 ns - is that correct?
I think you are confusing hold time and setup time.  10 ns would be a setup time
requirement - time from one clock to the next clock.  0.0 ns is a hold time
requirement which compares the relative delay of data and clock.  Normally
when both flip-flops  are on the same global clock net you don't get hold
violations because the clock skew is near zero and the minimum data delay
is significantly more than the clock skew.  When using two related clocks,
you need to be sure that the minimum data delay exceeds the clock skew.
"Hold time" is considered zero when the data changes at exactly the same
time as the clock at the receiving end of the path.
Gabor
-- Gabor
Instructor
Instructor
Gabor
-- Gabor
Visitor mbhardware
Thank you so much.
Now I will try to delay the second (slow) clock (phase shift), so that it is not synchronous to the first one.
Greets
michael
