mohammed.saleh
Timing analyzer problem
Hi, I have recently design a Schemtic in xilinx ISE14.7 version.But, before that i need to use XC9500 CPLD's obsolete family & shown a problem in the timing analyzer. i just attach a screenshot with this message . Please provide a sugggestion to solve this problem.
viviany
Is this a show-stop problem?
Looks like a warning. Fit completed successfully, didn't it?
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
mohammed.saleh
Yes, some other problem.
But its fine.
I have one more doudt
We are designing a schematic in Xilinx ISE 14.7 Version. So, now we are facing an issue in our design. In our previous design there is a symbol called “BUFE” But, in Xilinx 14.7 there is no such a symbol.
So, can you please suggest alternating symbol for BUFE.
viviany
Are you targeting CPLD or any other device?
-vivian
mohammed.saleh
We are curently designing for Spartan 6 board.
Mohammed Aboo Saleh
viviany
Spartan6 does not have BUFE component.
It has BUFG, BUFIO2, BUFPLL, BUFH.
Usually we use BUFG.
For details about clock resources, please refer to UG382.
-vivian
mohammed.saleh
BUFE Means buffer with enable it is also active High enable.
BUFG is a simple buffer.
So, can any other symbol can replace exact BUFE operation.
Mohammed Aboo Saleh
viviany
BUFG is actually one of the configurations of BUFGCTRL.
BUFGCTRL can be configured as BUFGCE.
I believe BUFGCE is what you need.
You can find the answer you need in UG382.
-vivian
