Timing constraint for this situation
Hi guys,
I have a design that includes 2 modules, syncrhonous to each other, A & B, using the same clock "clk".
However, A has to run in 2 modes where the clock "clk" may be either 150 or 300MHz.
In 150Mhz mode, Both A & B run, A & B talk to each other.
In 300MHz mode, the whole module B is not used,  and will be disabled.
Question: how to set constraint  the clock inside B to be 150M and the clock outside B 300MHz.. I don't like to have any buffer. Any idea?
When I apply constraint to the clock net under B, it overwrites the previous clock setting, for example
create_clock -name shared_clk -period 3.333 [get_nets clk]
create_clock -name B_clk -period 6.666 [get_nets instance_B/B_clk]
Then the shared_clk disappear.
What's the correct way to set constraints for this situation?
Thanks!!!
Jeff
Hi Jeff,
I agree that in your case Brucey's suggestion won't work.
And I don't think Deepika's suggestion will work as well, as -add will only cause an additional 150MHz clock, not overload the 300MHz clock.
I think the following should work:
1) constrain everything as 300MHz
2) constrain everything as 150MHz
3) overload (do not specify -add) the clock input of module B with only a 150MHz clock
4) make sure Vivado doesn't see cross-clock paths between 300MHz and 150MHz
create_clock -name clock_300MHz -period 3.333 [get_nets clk]
create_clock -name clock_150MHz -period 6.666 [get_nets clk]
create_generated_clock -name B_clk -source [get_pins instance_B/B_clk] \
-divide_by 1 [get_nets instance_B/B_clk] -master_clock clock_150MHz set_clock_groups –physically_exclusive –group clock_300MHz –group [get_clocks clock_150MHz -include_generated]
Best regards,
Dries
Give Kudos to a post which you think is helpful and reply oriented by clicking the star next to the post.
How about:
create_clock -name shared_clk -period 6.666 [get_nets clk]
create_clock -add -name A_clk -period 3.333 [get_nets instance_A/A_clk]
brucey
Hy Brucey,
Thanks for your suggestion.
However, I have other logic running at the top above A & B using the shared_clk which should run at 300MHz.
:-s
Did you try below in that case
create_clock -name B_clk -add -period 6.666 [get_nets instance_B/B_clk]
How are you choosing between the 150Mhz and 300Mhz clocks? Do you have a MUX? did you check set_case_analyis constraint?
Deepika.
Deepika.
Hi Jeff,
Best regards,
Dries
Hi Vemulad,
I've tried that but it didn't work as what I want.
What it does is : it creates 2 names for the same net and analyzes 2 clocks. The slow clock meets timing with huge positive slack. The fast one doest meet timing in both A & B modules.
In this situation, what i really want is: the tool should not try to route the module B to meet 300MHz. It should relax the routings for B and give "space" to the module A.
The shared clock is returned from GTX, depending on the line rate, I will get either 150MHz or 300MHz.
Jeff
Hi Dries,
This sounds reasonable.
I'll try and let you know.
Jeff
Awesome!!!!
IT WORKED !!!
THANKS!!!
KUDOS!!
I'm happy to hear that!
- Dries
I'm sorry to reopen this, but I have the exact same scenario, but unfortunately, driesd's solution doesn't seem to work for me (using Vivado 2014.4):
The first create_clock command is fine, but the second create_clock command returns with a critical warning:
CRITICAL WARNING: [Constraints 18-1056] Clock ' clock_250' completely overrides clock ' clock_500'.
"all_clocks" only returns the last clock (clock_250), not both.
The third command "create_generated_clock" fails with
ERROR: [Vivado 12-672] Cannot specify -master_clock without specifying -add.
My guess this is a problem with the my Vivado version 2014.4.
I tried a few things, but unfortunately without success so far:
The following test:
create_clock -period 2 -name clock_500 [get_ports clk_in]
create_clock -period 4 -name clock_250 -add [get_ports clk_in]
create_generated_clock -name fir_clk -source [get_pins design_1_i/hier_slow/aclk] -divide_by 1 -add -master_clock clock_250 [get_nets design_1_i/hier_slow/aclk]
set_clock_groups -physically_exclusive -group clock_500 -group [get_clocks clock_250 -include_generated]
which gave no warnings, but still resulted in Timing errors in design_1_i/hier_slow/, which showed that a 2ns period constraint was applied to hier_slow
The following test:
create_clock -period 4 -name clock_250 [get_ports clk_in]
gave a CRITICAL WARNING: [Constraints 18-1056] Clock ' clock_250' completely overrides clock ' clock_500', and  set_clock_groups  failed, because the clock_500 was no longer there.
The following test:
create_clock -period 4 -name clock_250 [get_ports design_1_i/clk_in]
gave no Critical warning and implementation gave no timing errors, so it first seemed to work, but when duplicating hier_slow as hier_fast (connected to design_1_i/clk_in), timing errors should have occurred in hier_fast, but suprisingly timing was met, so I assume, also hier_fast was constrained with 4ns from clock_250, instead of 2ns from clock_500.
It looks as if the constraint generated by create_generated_clock command is also applied to hier_fast, which is bad, as this part still needs to run at clock_500.
Any other ideas on how I can achieve the setup mentioned in the first post to relax timing constraints only for a block B (hier_slow), but keeping strict timing constraints for block A (hier_fast)?
Thanks!
Matthias
