Timing constraints Setting
Hi All,
I need a good tutorial/user information on usage of timing constraints using XILINX tool.
Thanks in Advance
with Regards,
Devs
Your question may be better suited for the "Timing Analysis" board, rather than the "Forum Usage" board.
But I would start here:
http://www.xilinx.com/itp/xilinx10/books/docs/timing_constraints_ug/timing_constraints_ug.pdf (Xilinx Timing Constraints User Guide)
Cheers,
bt
Hi ,
the link given by you is very much useful,
Thanks & Regards,
Devs
