Timing constraints not met
I am using Artix 7 fpga. What ever period I set, it is showing timing constraints not met. How to set correct period or timing constraints.timing.PNG
@girireddy,
Very wrong way to debug. And it should never be this way.
You clock should be more or less fixed and accordingly the design should be adapted.
Without the design details I cannot comment more.
FPGA enthusiast!
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer solved your problem.
Is it possible to see delay, power and frequency of the above design in vivado with applying any timing constraints
Your timing errors are hold time errors, not set up time errors.  Slowing your clock will not fix these.  You need to look at the failing paths and figure out why they are failing.
@girireddy,
To answer this question:
Depending what you mean, yes.
You can open your implemented design, and apply a new clock or a new timing constraint. And then rerun the timing check, and it will reflect those changes. Now, if this is because of missing false paths, it might let you know it all works, but if those constraints allow the tool to do something different, you will have to reimplement to see those changes.
