michaeldevid
Timing erros with RAMB16_S9_S9 and two different clocks
I’m an intern and designing an Gigabit Ethernetcamera with the Spartan-6 SP605 Evaluation Platform (XC6SLX45T). The camera data is written to the RAMB16_S9_S9  component with a clock of 48MHz. The data is read with a clock of 125MHz. But the code is designed so they never read or write from the same address.
The RAMB16_S9_S9 component is a dual clock RAM component witch should operate without problems with two different clock signals. But when I generate the Timing report I get these timing errors:
Met
Constraint
Check
Worst Case Slack
Best Case Achievable
Timing Errors
Timing Score
No
TS_CLOCK_GENERATION_clkout0 = PERIOD TIMEGRP "CLOCK_GENERATION_clkout0" TS_CLK_IN1 / 4.625 HIGH 50% INPUT_JITTER 0.37037 ns
SETUP HOLD
-4.506ns 0.293ns
44.056ns
77 0
252488 0
No
TS_CLOCK_GENERATION_clkout2 = PERIOD TIMEGRP "CLOCK_GENERATION_clkout2" TS_CLK_IN1 / 1.76190476 HIGH 50% INPUT_JITTER 0.37037 ns
SETUP HOLD
-1.639ns 0.462ns
55.440ns
11 0
16145 0
Yes
TS_CLK_IN1 = PERIOD TIMEGRP "CLK_IN1" 37.037 ns HIGH 50% INPUT_JITTER 0.37037 ns
MINLOWPULSE
27.036ns
10.000ns
0
0
Now the strange thing is that my design does work, it send and receives packets and I can view the camera image. Now when I change the clock of PORT A from the 48MHz to the same as PORT B thus the 125MHz signal.  I get these timing errors:
Met
Constraint
Check
Worst Case Slack
Timing Errors
Timing Score
No
SETUP HOLD
-1.563ns 0.268ns
20.512ns
8 0
10582 0
Yes
MINLOWPULSE
27.036ns
10.000ns
0
0
Yes
SETUP HOLD MINPERIOD
19.331ns 0.521ns 19.291ns
1.690ns 1.730ns
0 0 0
0 0 0
This is the code for the RAM block:
	RAMB16_S9_S9_001 : RAMB16_S9_S9
	port map (
		DOA => open,      -- Port A 8-bit Data Output
		DOB => DOB(J),      -- Port B 8-bit Data Output
		DOPA => open,    -- Port A 1-bit Parity Output
		DOPB => open,    -- Port B 1-bit Parity Output
		ADDRA => WPTR(10 downto 0),  -- Port A 11-bit Address Input
		ADDRB => RPTR(10 downto 0),  -- Port B 11-bit Address Input
		CLKA => PIX_CLK,    -- Port A Clock
		CLKB => CLK,    -- Port B Clock
		DIA => STREAM_DATA,      -- Port A 8-bit Data Input
		DIB => x"00",      -- Port B 8-bit Data Input
		DIPA => "0",    -- Port A 1-bit parity Input
		DIPB => "0",    -- Port-B 1-bit parity Input
		ENA => '1',      -- Port A RAM Enable Input
		ENB => '1',      -- PortB RAM Enable Input
		SSRA => '0',    -- Port A Synchronous Set/Reset Input
		SSRB => '0',    -- Port B Synchronous Set/Reset Input
		WEA => WEA(J),      -- Port A Write Enable Input
		WEB => '0'       -- Port B Write Enable Input
The read address/pointer is controlled by this code:
WPTR_GEN_001: process(ASYNC_RESET, PIX_CLK)
begin
	if(ASYNC_RESET = '1') then
		WPTR <= (others => '0');
	elsif rising_edge(PIX_CLK) then
		if(STREAM_DATA_VALID = '1') then
			WPTR <= (WPTR + 1) and PTR_MASK;
--increse the address at every data clock end if; end if; end process;
Now I’m wondering why this RAM component gives these timing errors. I have attached my .TWX file so you can see more information about the timing errors.
Michael
Using ISE v. 14.2
graces
In 14.1/14.2, there's a tool bug which mixes up the BRAM/FIFO's RDCLK and WRCLK requirement.
Please check out the following Design Advisory Answer.
http://www.xilinx.com/support/answers/51580.htm
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs.
