Timing warning when running par
Hi all,
I get the message below when running the place and route in a Spartan3-ADSP device
Thanks in advance
Andoni
Release 10.1.03 par K.39 (nt)
Copyright (c) 1995-2008 Xilinx, Inc.  All rights reserved.
MOORE::  Wed Nov 19 22:22:08 2008
par -ol high -w ./work/fpga_cf_dn_rb_wg_ac_pf.ncd
./work/fpga_cf_dn_rb_wg_ac_pf_pr.ncd ./work/fpga_cf_dn_rb_wg_ac_pf.pcf
Constraints file: ./work/fpga_cf_dn_rb_wg_ac_pf.pcf.
Loading device for application Rf_Device from file '3sd1800a.nph' in environment C:\Xilinx\10.1\ISE.
   "fpga_cf_dn_rb_wg_ac_pf" is an NCD, version 3.2, device xc3sd1800a, package cs484, speed -4
Initializing temperature to 85.000 Celsius. (default - Range: 0.000 to 85.000 Celsius)
Initializing voltage to 1.140 Volts. (default - Range: 1.140 to 1.260 Volts)
WARNING:Timing:3232 - Timing Constraint
   "TS_CLK_140 = PERIOD TIMEGRP "clk_140" 7.1 ns HIGH 3.55 ns;"
    fails the minimum period check for clock "clk_140" because the period constraint value (7100 ps) is less than the
   minimum internal period limit of 7350 ps  on pin
   "/fpga_cf_dn_rb_wg_ac_pf/PACKED/fpga_cf_dn_rb_wg_ac_pf/dn\/u2\/Mmult_dgain_mult0000/dn\/u2\/Mmult_dgain_mult0000/CLK"
   .   Please increase the period of the constraint to remove this timing failure.
   "TS_dcm1_CLK0_BUF = PERIOD TIMEGRP "dcm1_CLK0_BUF" TS_clk HIGH 50%;"
Re: Timing warning when running par
This message warn you that the clock frequency is beyond the requirement of that INST (it seems to be a DSP48A) due to input clock period constraint.
Please double chech the spartan3ADSP's datasheet.
Jared
Anonymous
Not applicable
Those warnings are for DCM pin limit check.
Which clock output has it gone out from the DCM? Which mode is the DCM working under?
The one that it producing the warning is the CLK0 output.
The DCM mode is a single DCM that produces two outputs, one is of the same frequency as the input and other which is half its frequency.
Andoni
