partha_g81
To add more switches to the synthesis options file
My synthesis script has options.tcl with  the following directives enabled
set_property STEPS.PLACE_DESIGN.ARGS.DIRECTIVE ExtraTimingOpt [get_runs impl_1]
set_property STEPS.ROUTE_DESIGN.ARGS.DIRECTIVE Explore [get_runs impl_1]
I want to add more switches to my options.tcl file along with the directives
place_design -directive ExtraTimingOpt -post_place_opt
route_design -directive Explore -tns_cleanup
Please suggest how to add the switches to the options file
Thans and Regds
Parth
hongh
Example:
set_property STEPS.PLACE_DESIGN.ARGS.DIRECTIVE RuntimeOptimized [get_runs impl_1]
set_property -name {STEPS.PLACE_DESIGN.ARGS.MORE OPTIONS} -value -post_place_opt -objects [get_runs impl_1]
set_property -name {STEPS.ROUTE_DESIGN.ARGS.MORE OPTIONS} -value -tns_cleanup -objects [get_runs impl_1]
hongh
Example:
