UCF: How to specify an async Pad to Pad delay
Dear experts,
I currently deal with a quite simple issue.
I just want to define a Timing constraint for the Inputs and the Output of a multiplexer. The multiplexer is controlled by a Register that is inside the FPGA.
Inputs are the FPGA Pads "P_A_in"  and  "P_B_in". Output is the pad "P_out"
I enter the following in my UCF file:
NET "P_A_IN" TNM_NET  = TNM_P_A_IN;
NET "P_OUT" TNM_NET = TNM_P_OUT;
TIMESPEC "TS_DELAY" = from TNM_P_IN to TNM_P_OUT 6 ns DATAPATHONLY;
But when compiling the design I finnally get the following Timing Report:
TS_DELAY = MAXDELAY FROM TIMEGRP "TNM_P_IN" TO TIMEGRP "TNM_P_OUT" 6ns;
0 items analyzed, 0 Timing Errors detected.
Actually I don't know why my simple combinatorial path from Input Pad to Output Pad is not analyzed.
What did I do wrong?
How can I achieve this constraint?
Please help. Any comments are welcome. It's quite urgent ;-(
Guide
Guide
Please don't post the same question more than once (although this looks like it was probably done by accident).
See the replies to the other post.
Avrum
