UCF constraints for reset synchronizer
I have a "reset bridge" in my scheme. And i have XDC constraints, how to correctly translate them into UCF?
XDC constraints:
set_property ASYNC_REG TRUE [get_cells {ldpc_top_inst/rst_sync_inst/pos_act_edge_rstn.rff1_reg ldpc_top_inst/rst_sync_inst/pos_act_edge_rstn.rff2_reg}]
set_max_delay -from [get_cells ldpc_top_inst/rst_sync_inst/pos_act_edge_rstn.rff1_reg] -to [get_cells ldpc_top_inst/rst_sync_inst/pos_act_edge_rstn.rff2_reg] 2
set_false_path -to [get_cells ldpc_top_inst/rst_sync_inst/pos_act_edge_rstn.rff1_reg]
I tried to convert them to UCF, but it seems to me that I'm doing something wrong:
INST "ldpc_top_inst/rst_sync_inst/rff1" ASYNC_REG = TRUE;
INST "ldpc_top_inst/rst_sync_inst/rff2" ASYNC_REG = TRUE;
NET "ldpc_top_inst/rst_sync_inst/rff1" MAXDELAY = 2ns;
And I do not understand how to translate these part:
Guide
Guide
Re: UCF constraints for reset synchronizer
@aikgg
I am not sure where you are getting your XDC constraints from. The naming convention is odd (with a . before the last hierarchical name) - that is not standard, it should be a slash, and your names have "extra stuff" in them (at least based on your schematic). Furthermore, the set_false_path is insufficient; it needs to go to both flip-flops, not just the first.
Other than the naming of the XDC, the ASYNC_REG constraints look correct in the UCF.
The mechanisms both you and @viviany used for the MAXDELAY are both OK, yours constraints the routing delay on the NET, Vivian's constrains the path delay. They are slightly different, but both accomplish what you want.
Similarly, the TIG constraint that Vivian gave is correct for the one pin you have in the set_false_path, but there should be another one for the other FF - so
PIN "ldpc_top_inst/rst_sync_inst/rff2.CLR" TIG;
should be added.
If the net driving the C pins has a name that you know, and it can go nowhere else then you can do
NET "<name_of_net> TIG;
instead.
Avrum
The "NET MAXDELAY" in UCF is not equal to the set_max_delay in XDC. A more appropriate UCF constraint is "FROM TO". The "FROM TO" constraint counts for the setup/hold spec of FFs and the clock skew, while "NET MAXDELAY" only constrain the routing delay of the net between the FFs.
TIMESPEC TS_maxdelay = FROM FFS(ldpc_top_inst/rst_sync_inst/rff1) TO FFS(ldpc_top_inst/rst_sync_inst/rff2) 2ns;
As for the set_false_path, you can use TIG constraint.
PIN "ldpc_top_inst/rst_sync_inst/rff1.CLR" TIG;
Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Guide
Guide
@aikgg
should be added.
instead.
Avrum
