UCF: tnm_net
Hi, I'm working with a Virtex-6 FPGA, so I have to use ISE. In the UCF Constraints Guide (UG625, http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/cgd.pdf, page 194) it is said, that I can constrain a clock net directly without using a tnm_net: NET “net_name” PERIOD = period {HIGH|LOW} [high_or_low_time] INPUT_JITTER value; But there is also the warning/recommendation not to do this: "Caution! This is a secondary method, and is not recommended." Specifying a tnm_net is probably useful, when you have several nets you want to group, but if this is not the case, will there be any problems using this "secondary method"?
Historian
Historian
Re: UCF: tnm_net
Just don't do it...
This "secondary" method has probably been obsolete for more than a dozen years. No one ever uses it. As such there is always a higher likelihood to encounter an untested "feature" associated with this format...
Other than the one extra line of UCF code, there really isn't any disadvantage to defining the group...
Avrum
